Normal Topic Vertical drag scroll on LineChart (Read 3370 times)
NymoBasePro
Jul 27th, 2021 at 5:33pm
When I drag the LineChart grid from left to right and right to left, it works beautifully.
I would like the same functionality if I drag the LineChart grid from up to down and down to up.
But now when I drag, nothing happens. I didn't find the setting for this. Also not sure if there is a setting for this.
Do I need to write the code myself? Can someone tell me how to solve this?
With kind regards,
Nymo
Re: Vertical drag scroll on LineChart
Reply #1 - Jul 27th, 2021 at 7:12pm
There's some built-in support implemented for plot's VerticalScroll property. That's used internally for scrolling horizontal barcharts, but should work for any kind of chart that includes a Plot2D. So you can't change both X and Y offsets with a single mouse drag, but you could toggle direction using a modifier key, e.g. -
void lineChart_KeyDown(object sender, KeyEventArgs e)
    var plot = (Plot2D)lineChart.Plot;
    plot.VerticalScroll = e.Shift;
void lineChart_KeyUp(object sender, KeyEventArgs e)
    plot.VerticalScroll = false;
Alternatively, enable ShowXRangeSelector and ShowYRangeSelector to let users scroll using the range scrollbars shown beside respective axes.
Kind regards,
NymoBasePro
Reply #2 - Jul 27th, 2021 at 7:48pm
Hi, thanks for the fast reply.
The KeyDown event doesn't trigger in my version but I got it to work with the mouse events:
private void lineChart_MouseDown(object sender, MouseEventArgs e)
    if (e.Button == MouseButtons.Right)
        plot.VerticalScroll = true;
private void lineChart_MouseUp(object sender, MouseEventArgs e)
Do you know if there are plans to add a solution for both horizontal and vertical?
Reply #3 - Jul 28th, 2021 at 6:12am
We'll have it in mind for next release.
