Normal Topic Link customization (Read 4221 times)
JaymeW
Link customization
Oct 27th, 2021 at 11:43am
Hi, I'm studying the customization of links and I have a question: is it possible to define the links created dynamically by the user to be a straight line? This is because depending on the position of the nodes, the link makes several curves to get to the node. One example:
Re: Link customization
Reply #1 - Oct 27th, 2021 at 11:58am
Set the Shape property of links to Polyline and disable AutoRoute.
JaymeW
Reply #2 - Oct 27th, 2021 at 12:57pm
I tried to add the following lines:
Code (Javascript)
var theme = new Theme();
var linkStyle = new Style();
linkStyle.setStroke("#7F7F7F");
linkStyle.setStrokeThickness(1.0);
linkStyle.setTextColor("#585A5C");
linkStyle.setFontName("Verdana");
linkStyle.setFontSize(3);
linkStyle.setShape('polyline');
linkStyle.setDynamic(false);
theme.styles["std:DiagramLink"] = linkStyle;
diagram.setTheme(theme);
Nodes stopped being displayed.
Reply #3 - Oct 27th, 2021 at 1:06pm
Try copying theme.styles["std:ShapeNode"] from Theme.Default.
JaymeW
Reply #4 - Oct 27th, 2021 at 2:44pm
It worked, thanks for the help.  Cheesy
JaymeW
Reply #5 - Oct 27th, 2021 at 2:49pm
One last question about customizing links. How could I adjust the text label to not be on top of the line like in the image?
Reply #6 - Oct 27th, 2021 at 3:00pm
Try different values from LinkTextStyle enum, which you can assign to TextStyle property. Alternatively call the addLabel method instead of setting Text, and either set LinkLabel's AutoArrange property, or specify your preferred offsets by calling one of the set*Position methods.
JaymeW
Reply #7 - Oct 18th, 2022 at 11:30am
Hi, I'm looking for a way to make the link color transparent. I need to show the user that the link they created is incorrect, so in addition to changing the color to red, I want the link to appear transparent. How can I do this?
Here an example:
Code (Javascript)
    var corLinkErrada = "#FF0000";
    var tamanhoLinkErrada = 2.0;
    link.setStroke(corLinkErrada);
    link.setStrokeThickness(tamanhoLinkErrada);
Reply #8 - Oct 18th, 2022 at 12:43pm
Try RRGGBBAA hex, or any other CSS notation for colors:
link.stroke = "#FF000099";
link.stroke = "rgba(255,0,0,0.6)";
JaymeW
Reply #9 - Oct 18th, 2022 at 3:22pm
Yes, thank you  Smiley
