Normal Topic Programmatically selecting a DockItem (Read 1513 times)
MavinTech
Nov 19th, 2021 at 7:10pm
I have a DockControl that has several DockItems in it and each Item contains a graphic display.  Is there a was to bring one of the items to be the current as if it was clicked on?  If someone tries to open a new DockItem that is already there, I want to select the item for them.
Re: Programmatically selecting a DockItem
Reply #1 - Nov 22nd, 2021 at 11:08am
Try this method:
void ActivateItem(DockItem item)
    var parent = item.Parent as DockWindowBase;
    if (parent != null)
        parent.SelectedIndex = parent.Items.IndexOf(item);
void ActivateItem(string id)
    var list = new List<DockItem>();
    dockControl.GetAllDockItems(list);
    foreach (var item in list)
        if (item.Id == id)
            ActivateItem(item);
            return;
