Normal Topic TableNode values not removed for recreation (Read 2440 times)
madhan1
FOLLOW NO ONE BUT LEARN
FROM EVERY ONE ..
Dec 7th, 2021 at 5:52am
Dear sir,
Code (C++)
 TableNode tbResources1 = diagram1.Factory.CreateTableNode(210, 10, 100, rowheight * itemIDs.Count);
            tbResources1.RowHeight = rowheight;
            tbResources1.RedimTable(1, itemIDs.Count);
            tbResources1.Caption = itemIDs[0][2].ToString();
            tbResources1.Font = new Font(FontFamily.GenericSansSerif, 9.0F, FontStyle.Italic, GraphicsUnit.Pixel);
            tbResources1.Pen = new MindFusion.Drawing.Pen(Color.FromArgb(192, 192, 192));
            tbResources1.CaptionHeight = rowheight;
            tbResources1.CaptionBrush = new MindFusion.Drawing.SolidBrush(Color.White);
            tbResources1.CaptionBackBrush = new MindFusion.Drawing.SolidBrush(Color.FromArgb(247, 150, 70));
            for (int i=1;i<itemIDs.Count;i++)
                tbResources[0, i-1].Text = itemIDs[i][1].ToString();
                tbResources1[0, i-1].Text = itemIDs[i][2].ToString();
                match1[i-1] = Convert.ToInt32(itemIDs[i][3])-1;
it is a function call for creating new questions i am using this same function.
but the issue is.
if some question set have 6 questions  and the next question set have 4 questions then
the before 2 questions is displaying in the next question
if you want something then go and grab it
Re: TableNode values not removed for recreation
Reply #1 - Dec 7th, 2021 at 7:57am
Assuming this code runs for each new set of questions, that would happen if itemIDs.Count remains the same as for previous set. Otherwise if you are reusing the TableNode and copying items somewhere else in the code, make sure you are calling RedimTable there too (or resetting the RowCount property).
madhan1
FROM EVERY ONE ..
Reply #2 - Dec 7th, 2021 at 8:14am
Dear sir,
Code (C++)
 void pickcurrentquestion()
            List<string[]> itemIDs = new List<string[]>();
            for (int i = 0; i < numberofQuestions; i++)
                if (allquestions[i, 0] == currentquestion.ToString())
                    itemIDs.Add(new string[4] { allquestions[i, 0], allquestions[i, 1], allquestions[i, 2], allquestions[i, 3] });
            if (itemIDs.Count < 1)
                MessageBox.Show("You have finished all the Questions :-)");
                return;
            int rowheight = 20;
            Array.Resize(ref match1, itemIDs.Count);
            TableNode tbResources = diagram1.Factory.CreateTableNode(10, 10, 100, rowheight * itemIDs.Count);
            tbResources.DeleteColumn(0);
            tbResources.RowHeight = rowheight;
            tbResources.RedimTable(1, itemIDs.Count);
            tbResources.Caption = itemIDs[0][1].ToString();
            tbResources.Font = new Font(FontFamily.GenericSansSerif, 9.0F, FontStyle.Italic, GraphicsUnit.Pixel);
            tbResources.Pen = new MindFusion.Drawing.Pen(Color.FromArgb(192, 192, 192));
            tbResources.CaptionHeight = rowheight;
            tbResources.CaptionBrush = new MindFusion.Drawing.SolidBrush(Color.White);
            tbResources.CaptionBackBrush = new MindFusion.Drawing.SolidBrush(Color.FromArgb(247, 150, 70));
            diagram1.Nodes.Add(tbResources);
            diagram1.Nodes.Add(tbResources1);
this is the function i am using. itemIDs.Count is created at the each time. here only i am creating the table node other than this i not creating any nodes.
madhan1
FROM EVERY ONE ..
Reply #3 - Dec 7th, 2021 at 2:20pm
Dear team,
       i found the issue. when ever i am calling the function.
i am creating a new table above the old table (because i am creating on same location)
so i delete the old table and then created the new table  Wink
Code (C++)
 TableNode L_tab, r_tab;
                L_tab = (TableNode)diagram1.FindNodeById("Lefttable");
                r_tab = (TableNode)diagram1.FindNodeById("Righttable");
                if (L_tab != null)
                    diagram1.Nodes.Remove(L_tab);
                    diagram1.Nodes.Remove(r_tab);
issue is solved thanks Slavcho
Reply #4 - Dec 7th, 2021 at 2:57pm
Ah right, that's slightly discernible from the doubled shadow in screenshot above Smiley
