Normal Topic About Calendar.LicenseKey (Read 6078 times)
e-doe132
Dec 18th, 2021 at 2:24am
Can someone tell where can I find the "Calendar.LicenseKey" properties?
Re: About Calendar.LicenseKey
Reply #1 - Dec 20th, 2021 at 8:00am
It's a property of the Calendar class -
https://www.mindfusion.eu/onlinehelp/webplanner/index.htm?P_MindFusion_Schedulin...
You could set it either in the aspx file or code behind -
<MindFusion:Calendar LicenseKey="XXX" />
void Page_Load(object sender, EventArgs e)
    _calendar.LicenseKey = "XXX";
