Normal Topic What is the Correct method of updating versions (Read 2152 times)
hyper
Jan 5th, 2022 at 9:39pm
Hi.  I have a WinForms license.
I downloaded a zip to version upgrade, named
WinFormsTrial.zip ; did setup, and then moved
the DLL's to my development.
Recompiled, and things look good, with my
existing license key.
Is this the correct approach, latest software?  It seems
to work; but will it revert to "Trial" ??  Is this the
correct way to upgrade the production software?
Thank you!
hyperscalper
Re: What is the Correct method of updating versions
Reply #1 - Jan 6th, 2022 at 7:39am
Thank you for choosing our product!
If you use the nuget package, you'd be able to update by clicking Update button in VS package manager -
https://www.nuget.org/packages/MindFusion.Diagramming/
Your license key should work for all versions released within an year after the purchase. If you want to be sure a new version will still work for you, you could check result of this method after calling AddLicense -
var valid = LicenseManager.CheckLicense(
    releaseDate, "MindFusion.Diagramming.WinForms");
