Normal Topic Different link shape for onLinkCreated (Read 2268 times)
Jessenberg
Jan 21st, 2022 at 3:44am
hello there, i'm now working on the different linkshape everytime someone created a link based on what link type they've chosen from the dropdown
[code javascript]SupportedBy(sender, args) {
var shape = mf.Diagramming.Shape.fromId("Triangle");
// var shape = "";
//...setLinkShape()
var origin = args.getLink().getOrigin().content.fileName;
console.log(shape);
args.getLink().setHeadShape(shape);
args.getLink().brush = "black";
if (origin == "/static/media/Solution.537801ea.svg") {
console.log("kiw");
this.state.diagram.removeItem(args.getLink());
// var DashStyle = mf.Drawing.DashStyle.Dash;
// args.getLink().strokeDashStyle = DashStyle;
}[/code]
how do i change the linkshape the moment a link is created ?
Re: Different link shape for onLinkCreated
Reply #1 - Jan 21st, 2022 at 7:50am
If you mean Polyline / Bezier / etc shape of link segments, you could set the Diagram.linkShape property in response to the dropdown change, and the control will then assign that automatically to the shape property of newly drawn links.
Jessenberg
Reply #2 - Jan 21st, 2022 at 8:09am
hello, so i tried doing that on the onChange function but somethings weird is happening
this is the onSelectChange:
Code (Javascript)
 onSelectChange(event) {
    console.log("Before value set " + this.state.behavior);
    this.setState({
      behavior: +event.target.value,
    console.log("After value set " + this.state.behavior);
this is the dropdown when it's called
Code (Javascript)
 <select
                className="item"
                defaultValue="4"
                onChange={this.onSelectChange.bind(this)}
                <option value="4">Supported By</option>
                <option value="4.1">In Context Of</option>
                <option value="4.2">Asserted</option>
                <option value="4.3">Defeated</option>
                <option value="4.4">Axiomatic</option>
                <option value="4.5">NeedsSupport</option>
                <option value="4.6">Assumed</option>
                <option value="4.7">Abstract</option>
                <option value="4.8">AsCited</option>
                <option value="3">LinkShapes</option> </select>
and this is on the link created :
Code (Javascript)
  onLinkCreated={(sender, args) => {
                var behave = this.state.behavior;
                console.log("actual value " + behave);
they return different values so i was confused, on the link created the behaviour value is correct but on the on change value it's wrong, since i'm trying to use a conditional for each linkshape
do you have any idea why is this happening? below is the log
Reply #3 - Jan 21st, 2022 at 11:09am
I'm not sure what that has to do with link.shape / diagram.linkShape if it's what you were referring to in initial post. I guess there's some other code changing the state.behavior in between onSelectChange and onLinkCreated calls.
Reply #4 - Jan 21st, 2022 at 1:35pm
Setting e.g. link.shape = LinkShape.Bezier in that loop should change the shape. Or link.setShape(LinkShape.Bezier) if you are still on V3 API. Bezier curvature might not be immediately visible, with control points staying on a straight line. You could offset the 2nd/3d coordinates of link.controlPoints a bit to add curvature, or try calling link.route() method.
Jessenberg
Reply #5 - Jan 25th, 2022 at 7:29am
Hello there, so i have question, this is my code to create a link
Code (Javascript)
 AssertedContex(sender, args) {
    var brush = mf.Drawing.Brush;
    console.log(shape);
    console.log(shape);
    var lab = "\u25CF";
    var label = args.link.addLabel(lab);
    // label.brush = "white";
    var Font = mf.Drawing.Font;
    label.font = new Font("Roboto", 5);
    label.horizontalAlign = mf.Diagramming.Alignment.Center;
    label.verticalAlign = mf.Diagramming.Alignment.Center;
i'm wondering how could i put the square so that it stay on the second control point or the point where the arrow converge
below is what i have now
Reply #6 - Jan 25th, 2022 at 7:51am
Try the LinkLabel.setControlPointPosition method.
Jessenberg
Reply #7 - Jan 27th, 2022 at 6:43am
thank you, it works just fine
