Normal Topic Diagramming for ASP.NET MVC, V4.0 (Read 2361 times)
Jan 27th, 2022 at 7:58am
We have released version 4.0 of MindFusion.Diagramming for ASP.NET MVC. It adds the following new features and improvements:
ES6 classes and properties
(client side / JavaScript)
Client side scripts have been refactored to use ES6 classes, properties and native collections. ArrayList, Dictionary and Set classes from MindFusion.Collections namespace have been removed, and replaced by respective JavaScript native Array, Map and Set. Get/set functions have been replaced by getter/setter properties, which should help using the diagram API with binding expressions of various JS frameworks. You could enable propFunctions in CompatConfig in order to continue using legacy get/set functions during migration.
Diagram view
The Diagram JavaScript class has been refactored into separate Diagram and DiagramView classes, matching respective server-side .NET classes that the library already provided in older versions. What remains of Diagram is now just a model class that defines diagram structure and implements serialization. The new DiagramView class deals with rendering and user interaction. You can show the same diagram in several views, each one rendering at different scroll positions and zoom levels. Note that you can no longer call Diagram.find(id) on client-side, but instead call DiagramView.find(id).diagram to access the Diagram object.
TreeView nodes
The TreeViewNode class represents nodes that can display hierarchical data. The root items displayed in the node can be accessed through the rootItems property. Items can be added and removed individually by using the addItem and removeItem methods, or in bulk by calling the fromObject method, which loads the tree view items from an array of objects.
Print pagination
The printPreview and print methods of DiagramView let you export the diagram as a list of smaller images in HTML page. Supported options include printArea (defaults to diagram's content bounds) and pageSize (defaults to DiagramView's viewport). Note that print methods use HTMLCanvasElement.toDataURL() internally, so any limitations it has will apply (such as canvas size and CORS).
.NET 6 support
Added assemblies and sample projects for .NET 6. The distribution still includes assemblies and samples for .NET 4.5+ and .NET Core 3.1.
Multi-touch support
  • If MultiTouchZoom property is enabled (default), the view can be zoomed or panned using two-touch pinch / flick gestures.
  • If MultiTouchModify property is enabled (default), diagram nodes can be moved, scaled and rotated using two-touch pinch / flick gestures.
  • If MultiTouchZoom property is disabled, each touch draws diagram items corresponding to current behavior.
  • If MultiTouchModify property is disabled, each touch started from a node draws a diagram link.
Latter modes can be used for collaborative whiteboarding / classroom scenarios.
Mouse input improvements
  • MouseWheelAction property of DiagramView lets you choose between Scroll (default) and Zoom as the default behavior of the control in response of a wheel event.
  • The MoveNodes behavior allows grabbing nodes to drag them without using adjustment handles.
  • The control now captures mouse events and completes drag / drawing operations even if mouse is released outside the diagram view.
New events
  • NodeSelectingScript, LinkSelectingScript, SelectionChangedScript events allow handling of selection interactions.
  • NodeTextEditingScript, LinkTextEditingScript and CellTextEditingScript validation events let you prevent users from editing a specific item
  • DataLoadedScript is raised when the diagram data is loaded from JSON or XML.
  • MouseWheelScript is raised when the user rotates the mouse wheel while the cursor is positioned over the diagram surface.
  • TreeItemTextEditingScript, TreeItemTextEditedScript allow handling of inplace-edit operations in TreeViewNode.
  • Client side createDiagramLink method now accepts two, three or four arguments, letting you specify row index for origin or destination TableNode, or TreeViewItem for origin or destination TreeViewNode.
  • OrthogonalLayout can now be applied on client-side.
  • Clipboard methods now use modern Navigator.clipboard API when their systemClipboard argument is enabled.
  • Rotation of FreeFormNode instances.
  • ImageAlign supports new FitLeft, FitTop, FitRight and FitBottom alignment styles, which resize image to fit node's boundaries and align it to respective border.
  • Fix for resizeToFitText not calculating correct size when cells have text padding applied.
  • ArrangeAsync method is now available in CoreCLR assemblies (.NET Core 3 and 6 versions).
  • The EnumAllPaths method of PathFinder yields each path immediately when found.
JavaScript API changes
  • getProperty/setProperty function pairs from client-side API have been replaced by ES6 getters/setters. Set CompatConfig.propFunctions to true in order to continue using legacy get/set functions in your code.
  • Diagram.find method has been removed. Call DiagramView.find instead, and get the view's diagram property.
  • Client-side scroll and zoom properties moved from Diagram to DiagramView: autoScroll, scrollZoneSize, autoScrollAmount, scrollX, scrollY, viewport, virtualScroll, zoomFactor.
  • Client-side input related properties moved from Diagram to DiagramView: allowInplaceEdit, delKeyAction, behavior, tooltipDelay, modificationStart, modifierKeyActions, leftButtonActions, middleButtonActions, rightButtonActions.
  • Client-side magnifier properties moved from Diagram to DiagramView: magnifierEnabled, magnifierFactor, magnifierWidth, magnifierHeight, magnifierFrameThickness, magnifierShading, magnifierShape,magnifierFrameColor, magnifierSecondaryFrameColor.
  • Client-side methods moved from Diagram class to DiagramView class: create, find, record, stopRecording, replay, clearTooltip, beginEdit, copyToClipboard, pasteFromClipboard, cutToClipboard, scrollTo, zoomToRect, zoomToFit, setZoomFactorPivot.
  • MindFusion.AbstractionLayer class has been removed.
  • EventArgs and CancelEventArgs classes have been moved to the MindFusion.Controls namespace.
  • ArrayList, Dictionary, ObservableCollection, Set classes have been removed from MindFusion.Collections namespace.
  • Due to Navigator.clipboard API being asynchronous, pasted items are not available immediately after calling pasteFromClipboard with systemClipboard enabled. You will be able to access them only after nodePasted and linkPasted events are raised.
.NET API changes
  • Server-side ContainerNode API is now consistent with client-side one. Containment is no longer implemented via a Group object and SubordinateGroup / MasterGroup properties. Instead, child nodes are now stored in the dedicated Children collection, and a node's container is returned by the Container property.
  • Suspend and Resume methods removed from ILinkRouter. Call Diagram's SuspendLinkRouter and ResumeLinkRouter methods instead.
  • Default LinkRouter changed from QuickRouter to CompositeRouter instance.
  • bool SmartPolylineEnds property of RoutingOptions replaced by
  • PolylineRouting enum property, which also provides an option to prevent inclined link segments for Polyline routes.
  • Removed ClientSideMode, MsAjaxLocation and JQueryLocation properties.
https://www.mindfusion.eu/MvcDiagramTrial.zip
Updated assemblies and script files are also available as MindFusion.Diagramming.Mvc NuGet package.
