Normal Topic WPF Virtual Keyboard failing license check (Read 1535 times)
Harshvir
Feb 5th, 2022 at 1:25am
I am running into an issue where when I try to use newer version of WPF Virtual Keyboard, then I get a message displaying trial version at the bottom of Keyboard. I tried to add check for license key, but its returning Invalid, I tried to EnableLogging, but the log file is not generated.
Can you please tell me if there are some license related changes with 5.0.1 and 5.0.2 version, and with updated version its failing license check and how can I fix it.
Re: WPF Virtual Keyboard failing license check
Reply #1 - Feb 5th, 2022 at 8:57am
From what I can see your company's maintenance (upgrades and technical support) has expired, so I guess the key you have is no longer valid for most recent version. It should still work for older releases from your year of upgrades.
« Last Edit: Feb 6th, 2022 at 9:53am by Slavcho »
Harshvir
Reply #2 - Feb 7th, 2022 at 3:10pm
Thanks for the information.
