Hot Topic (More than 10 Replies) Export excel (Read 4019 times)
jlagniez
Export excel
Feb 15th, 2022 at 1:29pm
I am new in the forum.
I would need an opinion on an export problem in excel with mindfusion.
First, I upgraded from .Net Framework 3.5.0 to .Net Framework 4.6.2 in order to use mindfusion version 6.7.
I can now export my diagram in excel but I have a problem:
- The labels are not displayed on my links on excel
I added images to illustrate the problem.
I also wanted to thank you for adding the excel export! It's a great feature
Re: Export excel
Reply #1 - Feb 15th, 2022 at 2:09pm
I think that's because Excel's connector shapes do not support text, or at least they did not when our developers created this exporter some years ago. Let us know if you are seeing a way to set connector's text in latest Excel UI.
At this time, you could try adding some temporary nodes on top of links before exporting, to serve as labels in the Excel diagram.
jlagniez
Re: Export excel
Reply #2 - Feb 15th, 2022 at 3:17pm
Thanks, yes that's a good idea, I'll give it a try.
I just tested and yes, you can't put a label on the connectors, it's also bad
jlagniez
Re: Export excel
Reply #3 - Feb 21st, 2022 at 1:58pm
We made the decision to split the connector into two connectors and add a shape with the value of the connector. This works. Thanks for the idea Smiley
There are still two problems that we cannot solve:
- Link size is not exported. We do newLink1.Pen.Width = 20
- The connector is not attached to the form. When I move the shape, the connector attaches correctly to the shape. I added images to illustrate the problem.
Jean-Marc
Re: Export excel
Reply #4 - Feb 22nd, 2022 at 9:37am
Try this build, it applies stroke width attribute to link shapes -
https://mindfusion.eu/_temp/diaglinks_excel.zip
We can't find any way to set exact control point coordinates in Excel, but can only specify connector's bounding rectangle. Our developer has adjusted that code to create more precise end points at least.
jlagniez
Re: Export excel
Reply #5 - Feb 22nd, 2022 at 11:11am
hi,
This version does not work no, could it come from me with an error not visible?
I understand ! It's a bad because there is "redirect the connector" on excel.
We used the LayeredLayout algorithm before the export. It's not perfect but it's a little better. (the LayeredLayout algorithm is really good  Smiley)
Jean-Marc
Re: Export excel
Reply #6 - Feb 22nd, 2022 at 12:25pm
Please attach a saved diagram with which it's not working.
jlagniez
Re: Export excel
Reply #7 - Feb 22nd, 2022 at 1:04pm
hi,
Diagram.SaveToFile(name), is it ok?
I add it as an attachment
Jean-Marc
Re: Export excel
Reply #8 - Feb 22nd, 2022 at 2:52pm
What's not working exactly? Link widths and end points from your file look correct on our end with last build. We can't find a way to add intermediate points to Excel connectors, so bends from LayeredLayout won't be visible in Excel. You might try using layouts that create straight lines only, so appearance is preserved in exported xlsx too - e.g. SpringLayout or AnnealLayout.
jlagniez
Re: Export excel
Reply #9 - Feb 23rd, 2022 at 8:12am
hi,
Ok, on my side, I don't have a different width on the excel connectors. I add an image
Jean-Marc
jlagniez
Re: Export excel
Reply #10 - Feb 23rd, 2022 at 8:19am
We also noticed that the more we increased the value of link.Pen.width, the more the connectors on excel were buggy.
Jean-Marc
Re: Export excel
Reply #11 - Feb 23rd, 2022 at 9:00am
Your project is still loading the old assemblies then. Please check if 'use specific version' property isn't set for references/Mindfusion*, and their path is the one where you unzipped patched dlls.
jlagniez
Re: Export excel
Reply #12 - Feb 23rd, 2022 at 9:38am
Yes ! That's right ! Everything is perfect ! Thanks very much.
Jean-Marc
