Normal Topic Custom Key (Read 2776 times)
Ken
Custom Key
Mar 3rd, 2022 at 3:39pm
I'm trying to create a custom template with a key on the keyboard that is only used for the @ symbol.
Is there a way to accomplish this?
Re: Custom Key
Reply #1 - Mar 3rd, 2022 at 4:11pm
Assuming you also don't want the regular @ key to send 2 depending on Shift state, you could make that key the only UnicodeKey instance in your custom layout, and then create a global UnicodeKey template in Xaml -
<DataTemplate DataType="{x:Type vk:UnicodeKey}">
	<ContentControl HorizontalContentAlignment="Center" VerticalContentAlignment="Center">
		<TextBlock Text="{Binding Character}"/>
	</ContentControl>
</DataTemplate>
Otherwise if you only need to use different colors or font for @, it should also be possible to use a data trigger in the template that checks for @ value and applies respective property setters.
Ken
Re: Custom Key
Reply #2 - Mar 3rd, 2022 at 4:23pm
Sorry, I'm new to windows programming with WPF so some of that wasn't exactly clear to me.
However; What I'm trying to accomplish is a keyboard that has the normal 2/@ key on it, but I want to add a key that only types the @ key regardless of the shift state.
Re: Custom Key
Reply #3 - Mar 3rd, 2022 at 4:48pm
You could use KeyboardCreator to add UnicodeKey to your custom layout, setting its Character to @. Load the layout file by calling -
keyboard.TemplateLayout = KeyboardLayout.Create(filePath);
Add the template to a resource dictionary somewhere in your Xaml -
<Window ...>
	<Window.Resources>
			</ContentControl>
		</DataTemplate>
	</Window.Resources>
