Normal Topic Drawing Lines with Flow Diagramming without Snapping (Read 2372 times)
nametable
Mar 24th, 2022 at 6:35pm
Hi, I am currently working on a project where I have DiagramLinks that users can create. These links are working fine for the most part. However, I am trying to figure out if it is possible to disable the snapping of DiagramLinks to nodes?
Is it possible to draw freeform lines with DiagramLinks which do not snap to anything?
Initially I thought that the Diagram would have a property somewhere that I could disable, but I have not found one which gives me the desired behavior.
I am using MindFusion Diagramming WPF version 2.5.
Thanks Smiley
nametable
Re: Drawing Lines with Flow Diagramming without Snapping
Reply #1 - Mar 24th, 2022 at 7:48pm
Here is an example showing the snapping I am referring to. After the link is placed however, the link behaves in the way that I want.
Reply #2 - Mar 25th, 2022 at 7:12am
There is no property for disabling that. You could implement it with some event handling instead -
Point unalignedStart;
Point unalignedEnd;
void OnLinkCreating(object sender, LinkValidationEventArgs e)
	unalignedStart = e.Link.StartPoint;
	unalignedEnd = e.Link.EndPoint;
void OnLinkCreated(object sender, LinkEventArgs e)
	e.Link.StartPoint = unalignedStart;
	e.Link.EndPoint = unalignedEnd;
	e.Link.UpdateFromPoints();
nametable
Reply #3 - Mar 29th, 2022 at 5:40pm
Thanks!
That method seems to work exactly in the way that I need.
I did however need to use ControlPoints to get and set the point values.
unalignedStart = e.Link.ControlPoints[0];
unalignedEnd = e.Link.ControlPoints[1];
Have a good day.
Reply #4 - Mar 30th, 2022 at 6:59am
Apparently StartPoint and EndPoint are available since v2.8.
