Normal Topic How to make it so items are uneditable (Read 1817 times)
Michael Hopkins
Apr 22nd, 2022 at 6:18pm
We want to make it so the items on the calendar are not able to be edited or draggable or resized. I tried to do the following.
Code (Java)
calendar.setAllowDrag(false);
calendar.setAllowInplaceCreate(false);
calendar.setAllowInplaceEdit(false);
calendar.setAllowMoveUnselectedItems(false);
calendar.setAllowAutoScroll(false);
But I was still able to drag and resize the item. What am I missing?
UPDATE:
I was able to suppress the dragging and resizing by catching the itemClick event and calling calendar.resetDrag(). It will still change the cursor when you hover an edge to the resize cursor as though it can be edited though... Seems like there is still something I am missing.
Is there a difference between setting items as non editable on the month view vs the timetable view. I am working items on a timetable view and I don't want them to be moved around or resized at all.
« Last Edit: Apr 22nd, 2022 at 11:12pm by Michael Hopkins »
Re: How to make it so items are uneditable
Reply #1 - Apr 25th, 2022 at 5:49am
Try item.setLocked(true);
Michael Hopkins
Reply #2 - Apr 25th, 2022 at 3:28pm
That worked. Thank you. Smiley
Bruno Dufour
Reply #3 - Aug 1st, 2022 at 10:05pm
I tried Appointment.setLock(true), and I still able to edit text. I missed something ?
Reply #4 - Aug 2nd, 2022 at 1:31pm
setLocked prevents changing item's date. You could prevent editing text by handling CalendarListener.itemInplaceEditStarting event.
Bruno Dufour
Reply #5 - Aug 2nd, 2022 at 6:57pm
Calendar member :
setAllowInplaceEdit
works for me.
