Normal Topic Inline Icons in item detail and title? (Read 1181 times)
Michael Hopkins
May 5th, 2022 at 11:57pm
Is there an easy way to add an icon into the detail or title of an item?
Our goal is to mix both text and icons into the detail and title of the item.
Michael
PS. We are already using the setImage on the item and using that to deliver some information to the user. We are hoping to have a few more in the items title.
Re: Inline Icons in item detail and title?
Reply #1 - May 6th, 2022 at 6:46am
Easiest is to use Unicode icons; potentially create your own font file if you need custom images.
e.getItem().getStyle().setHeaderFont(
	new Font("Segoe UI Emoji", Font.PLAIN, 15));
e.getItem().setHeaderText("coffee \u2615 time");
Otherwise it could probably be done with custom drawing using some html rendering library. E.g. if JLabels can display images in their html mode, try solution from https://stackoverflow.com/questions/7774960/swing-html-drawstring
