Normal Topic No gap between the Node and the node name (NodeListView) (Read 1409 times)
jose_au
May 9th, 2022 at 3:29am
I am struggling to render the nodelist in an accordion style view using boostrap 4.
<div class="card">
    <div class="card-header">
        <a class="card-link" data-toggle="collapse" href="#allNodes">
            <div class="text-left" style="float: left;">All Shapes</div>
            <div class="text-right">></div>
        </a>
    </div>
    <div id='allNodes' class="card-body p-1 collapse">
        @Html.NodeListView(nodeListView,
            new { style = "height: 500px; width:''!important;" });
    </div>
</div>
As you can see the initial state of the accordion is collapsed. So I expect this to not render in the background. However, the NodeListView does render but there is no gap between the NodeShape and the name (see screenshot).
Any ideas how I can add some gaps?
Re: No gap between the Node and the node name (NodeListView)
Reply #1 - May 9th, 2022 at 9:33am
That seems to work with current version of the control -
https://mindfusion.eu/_samples/Accordion.zip
Problem might have to do with initial visibility of the list view, was fixed at some point before a November 2020 release of our standalone JS library mentioned here -
https://mindfusion.eu/Forum/YaBB.pl?num=1615385530/7#7
You might check if you have access to more recent MVC versions than that at your https://www.clientsarea.eu/ account page.
