Normal Topic Cannot create link from ShapeNode. Won't initiate LinkCreating (Read 1584 times)
Viev
May 13th, 2022 at 2:03am
Hi there,
I can't create links from a ShapeNode. Every time I try, the lasso multi-select box appears, rather than starting to draw a shape.
See attached.
DiagramView
    Behavior = DrawLinks
Shape
    AllowOutgoinglinks = True
    HandlesStyle = HandlesStyle.Invisible
    EnabledHandles = AdjustmentHandles.Move
I don't understand.
There is some simple setting on either DiagramView, Diagram or ShapeNode that is missing and I can't seem to find it.
Any information most welcome.
Sincerely,
Victor
Viev
Re: Cannot create link from ShapeNode. Won't initiate LinkCreating
Reply #1 - May 13th, 2022 at 2:44am
Solved - Below
Diagram
    AllowUnanchoredLinks = True
I also set AllowUnconnectedLinks = True
Reply #2 - May 13th, 2022 at 7:37am
Hi Victor,
Indeed, this from the docs:
Quote:
true to let links connect to nodes without anchor points; otherwise, false. The default is true.
Remarks
AllowUnanchoredLinks applies to nodes whose AnchorPattern is not set or does not contain incoming or outgoing anchor points available. If the property is enabled, users can connect links to any point of such nodes. If disabled, users cannot connect links to such nodes
