Normal Topic Reminder app issues (Read 4012 times)
bianca2210
Reminder app issues
May 13th, 2022 at 11:45am
I am a new member of mindusion, and I am trying to create the reminder app. But I interfaced a lot of errors, can someone help me?
for e.a:
ERROR in src/app/components/reminder/Scripts/jsplanner.d.ts:19:37 - error TS2339: Property 'Common' does not exist on type 'typeof MindFusion'.
Re: Reminder app issues
Reply #1 - May 14th, 2022 at 7:13am
You can find TypeScript examples in JsScheduler\Samples\TypeScript folder from distribution. All runtime scripts and d.ts definitions will be downloaded from npm if you add this to your package.json:
"dependencies": {
    "@mindfusion/scheduling": "^2.0.0"
E.g. after running npm install in TypeScript samples folder, you can find the Common module definitions under JsScheduler\Samples\TypeScript\node_modules\@mindfusion\common\common.d.ts.
If you are not using npm and module bundlers but referencing d.ts files manually, you can find them all under JsScheduler\Scripts folder from distribution. In such case, you might have to load the definitions in same order as listed for runtime js files in "getting started" docs: drawing, controls, common, common-collections, scheduling.
bianca2210
Reply #2 - May 16th, 2022 at 11:05am
Thank for your response Smiley
I still have some errors Sad
import MindFusion
Module '"@mindfusion/scheduling"' has no exported member 'MindFusion'.ts(2305)
Reply #3 - May 16th, 2022 at 12:33pm
Could you attach a test project showing your setup?
