Normal Topic Multiple font sizes in the text of a shapenode. (Read 1784 times)
Mindfusion User
Jun 7th, 2022 at 1:05pm
Can we apply multiple font sizes to different words in the text of a ShapeNode?
With the font property of a node, we can specify a distinct font for each node. But we need to specify multiple font sizes to the text of one node.
With the property "ShapeNode.enableStyledText", we can enable styled text and thus apply 'italic/bold/underlined/text color/subscript/superscript/..." to parts of the ShapeNode text.
Our current solution is to use the tag "subscript" of "enableStyledText" for text words that need a smaller font size.
Is there a better way to do this?
Kinds regards,
Mindfusion user.
Re: Multiple font sizes in the text of a shapenode.
Reply #1 - Jun 7th, 2022 at 1:54pm
We'll try to add styled-text <size> tag for next release. If you don't need the differently-sized words arranged in same text flow, you could try using NodeLabel objects instead, but will have to position them yourself.
Mindfusion User
Reply #2 - Jun 8th, 2022 at 12:05pm
Thank you for the information.
Kind regards,
M.U.
Reply #3 - Jul 26th, 2022 at 12:51pm
Scripts here add support for size element -
https://mindfusion.eu/_beta/jsdiag423.zip
function onNodeCreated(sender, e)
	e.node.enableStyledText = true;
	e.node.font = new Font("Arial", 16, false, false);
	e.node.text = "test <size=12>test</size> <size=8>test</size>";
Mindfusion User
Reply #4 - Aug 19th, 2022 at 7:06am
Thanks, this is much better!! Smiley
