Normal Topic Testing MindFusion, calendar with rangeselector (Read 3605 times)
Bruno Dufour
Jul 28th, 2022 at 2:34pm
I am testing Canlendar and ressource time line with Rangeselector.
When instantiating rangeselector to build graphical interface, it returns NULL when calling constructor...
Any clues?
Re: Testing MindFusion, calendar with rangeselector
Reply #1 - Jul 28th, 2022 at 2:55pm
I haven't heard of constructors returning null. On what OS and Java versions are you trying that, and does it show any exceptions in console? You can find RangeSelector demonstrated in the ResourceTimeline example from distribution.
Bruno Dufour
Reply #2 - Jul 28th, 2022 at 8:44pm
It works with the demonstrator but not when I extract the sample to test it into a new java class.
The exception:
2022-07-28 16:42:01:245 >>>> [Py:1,Th:AWT-EventQueue-0]>SCHEDULING_LOG : Could not insert operation : [ BT220616-03-1 ] Libération {Libération } in assigned resource : Libération
java.lang.NullPointerException
     at com.mindfusion.common.RangeSelector.<init>(Unknown Source)
     at com.notixia.common.client.scheduling.simple.cSimpleGanttComponent.mBuildUI(cSimp
leGanttComponent.java:83) .
     at com.notixia.common.client.scheduling.simple.cSimpleGanttComponent.<init>(cSimple
GanttComponent.java:43)
     at com.notixia.common.client.scheduling.simple.cSimpleSchedulingApplicationView.mGe
tSpecificPane(cSimpleSchedulingApplicationView.java:134)
     at com.notixia.common.client.cGenericADOTreeTableAV$cBackgroundModelPreparation$2.r
un(cGenericADOTreeTableAV.java:673)
     at java.awt.event.InvocationEvent.dispatch$$$capture(InvocationEvent.java:311)
     at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java)
     at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)
     at java.awt.EventQueue.access$500(EventQueue.java:97)
     at java.awt.EventQueue$3.run(EventQueue.java:709)
     at java.awt.EventQueue$3.run(EventQueue.java:703)
     at java.security.AccessController.doPrivileged(Native Method)
     at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Pr
otectionDomain.java:74)
     at java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
     at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205
     at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
     at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105
     at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
     at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
     at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
Warning: Could not get charToByteConverterClass!
S
CLASS source:
package com.notixia.common.client.scheduling.simple;
import com.mindfusion.common.*;
import com.mindfusion.drawing.*;
import com.mindfusion.scheduling.*;
import com.mindfusion.scheduling.Calendar;
import com.mindfusion.scheduling.model.Appointment;
import com.mindfusion.scheduling.model.Resource;
import com.notixia.common.model.resource.cAPMResource;
import com.notixia.ecip.client.cDefaultToolBar;
import com.notixia.ecip.core.cProxy;
import com.notixia.ecip.model.cADOID;
import javax.swing.*;
import java.awt.*;
import java.awt.event.*;
import java.awt.geom.Rectangle2D;
import java.util.*;
public class cSimpleGanttComponent extends JPanel implements ItemListener {
    Calendar aCalendar;
    RangeSelector aTimeLine;
    private JRadioButton aView1;
    private JRadioButton aView2;
    private JRadioButton aView3;
    boolean initialized;
     * A list with all defined zones.
    private ArrayList<cSimpleZone> zones = new ArrayList<>();
    public cSimpleGanttComponent(java.util.List<cSimpleResource> pSimpleResources) {
        super(new BorderLayout());
        this.addComponentListener(new ComponentAdapter() {
            public void componentResized(ComponentEvent e) {
                updateTimeline();
        mBuildUI();
        mInitResources(pSimpleResources);
        mInitZones();
        for(cSimpleResource lResource : pSimpleResources)
            java.util.List<cSimpleOperation> lListOfSimpleOperations = lResource.mGetSequence();
            for(cSimpleOperation lSimpleOperation : lListOfSimpleOperations)
                aCalendar.getSchedule().getItems().add(lSimpleOperation);
        add(BorderLayout.CENTER, aCalendar);
        add(BorderLayout.SOUTH, aTimeLine);
    private void mInitZones()
        java.util.Calendar lCalendar = java.util.Calendar.getInstance();
        lCalendar.set(2022,java.util.Calendar.JULY,26,9,0);
        Date lD1 = lCalendar.getTime();
        lCalendar.set(2022,java.util.Calendar.JULY,27,9,0);
        Date lD2 = lCalendar.getTime();
        DateTime lBegin = new DateTime(lD1);
        DateTime lEnd = new DateTime(lD2);
        cSimpleZone lZone = new cSimpleZone(lBegin, lEnd, "hey",true);
        zones.add(lZone);
    private void mInitResources(java.util.List<cSimpleResource> pSimpleResources) {
        for (cSimpleResource lResource : pSimpleResources)
            aCalendar.getResources().add(lResource);
        aCalendar.setGroupType(GroupType.GroupByResources);
    private void mBuildUI() {
        aTimeLine = new RangeSelector();            <<<<<<<<<<<<<<< This is the line 83
        aTimeLine.setButtonSize(12);
        aTimeLine.setLocation(0, 430);
        aTimeLine.setMinimum(0D);
        aTimeLine.setName("timeline");
        aTimeLine.setSize(628, 65);
        aTimeLine.setPreferredSize(new Dimension(628, 65));
        aTimeLine.addRangeSelectorListener(new RangeSelectorListener(){
            @Override
            public void valueChanged(EventObject e)
                aCalendar.setViewport(new DateTime((long)aTimeLine.getSelectionStart()),
                        new DateTime((long)aTimeLine.getSelectionEnd()), true);
                aTimeLine.repaint();
            @Override
            public void drawBackground(DrawEvent e)
                Rectangle2D bounds = e.getBounds();
                Graphics2D g = (Graphics2D)e.getGraphics();
                // Draw days
                DateTime date = aCalendar.getDate();
                while (date.isLessThan(aCalendar.getEndDate()))
                    double prc = (double)(date.getTicks() - aCalendar.getDate().getTicks()) / (aCalendar.getEndDate().getTicks() - aCalendar.getDate().getTicks());
                    int x = (int)(bounds.getX() + (int)(prc * bounds.getWidth()));
                    Pen pen = new Pen(aCalendar.getResourceViewSettings().getStyle().getBorderLeftColor());
                    pen.applyTo(g);
                    g.drawLine(x, (int)bounds.getY(), x, (int)(bounds.getY()+bounds.getHeight()));
                    Brush brush = new SolidBrush(aCalendar.getResourceViewSettings().getStyle().getHeaderTextColor());
                    Font f = aCalendar.getResourceViewSettings().getStyle().getHeaderFont();
                    g.setFont(f);
                    brush.applyTo(g, bounds);
                    g.drawString(date.toString("MMM"), x+2, (int)(bounds.getY()+bounds.getHeight()-2));
                    date = date.addDays(DateTime.daysInMonth(date.getYear(), date.getMonth()) - date.getDay() + 1);
        aView1 = new JRadioButton("Gantt");
        aView2 = new JRadioButton("Calendar");
        aView3 = new JRadioButton("Week");
        aView1.setSelected(true);
        aView1.addItemListener(this);
        aView2.addItemListener(this);
        aView3.addItemListener(this);
        ButtonGroup lGroup = new ButtonGroup();
        lGroup.add(aView1);
        lGroup.add(aView2);
        lGroup.add(aView3);
        cDefaultToolBar lToolbar = new cDefaultToolBar();
        lToolbar.add(aView1);
        lToolbar.add(aView2);
        lToolbar.add(aView3);
        add(BorderLayout.NORTH, lToolbar);
        aCalendar = new Calendar();
        aCalendar.addCalendarListener(new CalendarAdapter() {
            public void draw(CalendarDrawEvent e) {
                calendar_Draw(e);
            public void itemCreating(ItemConfirmEvent e) {
                onCalendarItemCreating(e);
            public void itemModifying(ItemModifyConfirmEvent e) {
                onItemModifying(e);
            public void itemCreated(ItemEvent e) {
                onItemCreated(e);
            public void itemClick(ItemMouseEvent e) {
                onItemClick(e);
        aCalendar.setCurrentTime(DateTime.now());
        lCalendar.roll(java.util.Calendar.MONTH,-1);
        Date lBegin = lCalendar.getTime();
        lCalendar.roll(java.util.Calendar.MONTH,14);
        Date lEnd = lCalendar.getTime();
        aCalendar.setDate(new DateTime(lBegin));
        aCalendar.setEndDate(new DateTime(lEnd));
        aCalendar.getTimetableSettings().getDates().add(new DateTime(lBegin));
        aCalendar.getTimetableSettings().getDates().add(new DateTime(lEnd));
        aCalendar.setTheme(ThemeType.Light);
        aCalendar.getMonthSettings().setWeekHeaderStyle(MonthWeekHeaderStyle.Left);
        aCalendar.getListViewSettings().setCellUnits(TimeUnit.Month);
      //  aCalendar.setCustomDraw(EnumSet.of(CustomDrawElements.TimetableCell));
        EnumSet<ListViewHeaderStyles> style = aCalendar.getListViewSettings().getHeaderStyle();
        style.add(ListViewHeaderStyles.Subheader);
        style.add(ListViewHeaderStyles.SubheaderPerCell);
        aCalendar.getResourceViewSettings().setViewStyle(ResourceViewStyle.Lanes);
        aCalendar.getResourceViewSettings().getMiddleTimelineSettings().setUnit(TimeUnit
.Day);
        aCalendar.getResourceViewSettings().getMiddleTimelineSettings().setFormat("d");
        aCalendar.getResourceViewSettings().getBottomTimelineSettings().setUnit(TimeUnit
.Hour);
        aCalendar.getResourceViewSettings().getBottomTimelineSettings().setFormat("HH:mm
        aCalendar.getTimetableSettings().setShowInfoHeader(true);
        aCalendar.getTimetableSettings().setVisibleColumns(3);
        aCalendar.getTimetableSettings().setSnapInterval(Duration.fromMinutes(1));
        aCalendar.setInteractiveItemType(cSimpleZoneEvent.class);
        aCalendar.setCurrentView(CalendarView.ResourceView);
        aCalendar.setCustomDraw(EnumSet.of(CustomDrawElements.ResourceViewTimeline));
        aCalendar.addCalendarListener(new CalendarAdapter(){
            @Override
            public void hScroll(ScrollEvent e)
                if (e.getType() == 5)//ScrollEventType.EndScroll)
                    updateTimeline();
        aCalendar.addComponentListener(new ComponentAdapter()
            @Override
                if (!initialized)
                    initialized = true;
                super.componentResized(e);
        // Calendar initialization end
        initTimeline();
        updateTimeline();
        aCalendar.invalidate();
    void initTimeline()
        DateTime start = aCalendar.getDate();
        DateTime end = aCalendar.getEndDate();
        aTimeLine.setMinimum(start.getTicks());
        aTimeLine.setMaximum(end.getTicks());
        aTimeLine.setMinimumSelectionLength((aTimeLine.getMaximum() - aTimeLine.getMinimum()) / 30);
        aTimeLine.setStep(Duration.TicksPerDay);//TimeSpan.TicksPerDay;
        aTimeLine.setSelectionStart(aTimeLine.getMinimum());
        aTimeLine.setSelectionEnd(aTimeLine.getSelectionStart() + aTimeLine.getMinimumSelectionLength());
    void updateTimeline()
        aTimeLine.setSelectionStart(aCalendar.getFirstVisibleDate().getTicks());
        aTimeLine.setSelectionEnd(aCalendar.getLastVisibleDate().getTicks());
    @Override
    public void itemStateChanged(ItemEvent e) {
        if (e.getSource() == aView1)
            if (aView1.isSelected())
        else if (e.getSource() == aView2)
            if (aView2.isSelected())
                aCalendar.setCurrentView(CalendarView.MonthRange);
                aCalendar.setCustomDraw(EnumSet.of(CustomDrawElements.MonthContents));
        else if (e.getSource() == aView3)
            if (aView3.isSelected())
                aCalendar.setCurrentView(CalendarView.WeekRange);
                aCalendar.setCustomDraw(EnumSet.of(CustomDrawElements.WeekRangeResourceHeader));
//    protected void btnZoneBClick()
//        addZone(false);
//    protected void btnZoneAClick()
//        addZone(true);
//    protected void btnDeleteClick()
//        for (int j = 0; j < zones.size(); )
//            Zone z = zones.get(j);
//            // Check if zone is selected
//            boolean found = false;
//            for (int i = 0; i < calendar.getSelection().getRanges().size(); i += 2)
//                DateTime start = calendar.getSelection().getRanges().get(i);
//                DateTime end = calendar.getSelection().getRanges().get(i + 1);
//                if (intersect(z.getStart(), z.getEnd(), start, end))
//                    zones.remove(j);
//                    found = true;
//                    // Remove all items from the zone
//                    for (int k = 0; k < calendar.getSchedule().getItems().size(); )
//                        Item item = calendar.getSchedule().getItems().get(k);
//                        if (intersect(z.getStart(), z.getEnd(), item.getStartTime(), item.getEndTime()))
Reply #3 - Jul 29th, 2022 at 6:20am
What OS and Java version are you using? Does this print null in your application if you call it before the RangeSelector call?
System.out.println(
    javax.swing.UIManager.get("ScrollBar.width"));
Bruno Dufour
Reply #4 - Jul 29th, 2022 at 11:28am
It returns null.
OS : linux.
Running Java 11.
Good to know:
The application is using Nimbus.
            static {
        try {
            UIManager.setLookAndFeel(new NimbusLookAndFeel());
        } catch (final Throwable ex) {
            System.out.println("Look and feel exception");
Reply #5 - Jul 29th, 2022 at 2:05pm
This build should fix the exception -
https://mindfusion.eu/_temp/range_selector_nimbus.zip
Bruno Dufour
Reply #6 - Jul 29th, 2022 at 6:01pm
Is it available through maven ?
I still have the same problem but I can't tell if it is due to inappropriate usage of your jar in my Intelij project.
« Last Edit: Jul 29th, 2022 at 8:43pm by Bruno Dufour »
Reply #7 - Jul 30th, 2022 at 9:00am
The patch is not on Maven yet. You should be able to use the old JAR too by setting that property before instantiating the RangeSelector -
javax.swing.UIManager.put("ScrollBar.width", 17);
