Normal Topic Dynamically adjust the size of the flowchart canvas. (Read 1184 times)
JaymeW
Aug 27th, 2022 at 12:42pm
Hello.
Is there any way to allow the flowchart canvas to be responsive when changing the canvas size dynamically? For example, if I want to adjust my Browser's canvas, I want the flowchart's canvas to also adjust to the size of the screen. It is possible?
Online
Re: Dynamically adjust the size of the flowchart canvas.
Reply #1 - Aug 28th, 2022 at 10:24am
Try this -
var viewDiv = document.getElementById("view");
new ResizeObserver(viewResized).observe(viewDiv);
function viewResized()
    let xPixels = viewDiv.offsetWidth;
    let yPixels = viewDiv.offsetHeight;
    // convert size to diagram units
    var unitSize = diagramView.clientToDocOffset({ x: xPixels, y: yPixels });
    // don't make the scrollable area smaller
    var unitWidth = Math.max(diagram.bounds.width, unitSize.x);
    var unitHeight = Math.max(diagram.bounds.height, unitSize.y);
    diagram.bounds = new Rect(0, 0, unitWidth, unitHeight);
https://developer.mozilla.org/en-US/docs/Web/API/Resize_Observer_API
JaymeW
Reply #2 - Sep 11th, 2022 at 1:35pm
I have a problem when I try to resize the flowchart canvas using
Code (Javascript)
The old canvas remains inside the Div and strange behavior happens as if two canvases exist at the same time and the nodes start blinking. How could I remove the old canvas before creating a new one?
JaymeW
Reply #3 - Sep 11th, 2022 at 3:03pm
Hi, nevermind, I managed to fix the problem and thanks for the help. Smiley
