Normal Topic Links not drawn correctly (Read 1804 times)
CODISMA
Oct 5th, 2022 at 6:27pm
I'm drawing a diagram programmaticaly.
All nodes have an AnchorPattern and I'm using OriginAnchor and DestinationAnchor members of DiagramLink to connect a link from a node to another.
And I'm using RouteAllLinks() method at the end but unfortunately some links are not drawn as they are expected to be (screenshot1).
But If I move one node, the links connected to this node are updated correctly (screenshot2).
Can you help me with that please.
Online
Re: Links not drawn correctly
Reply #1 - Oct 6th, 2022 at 7:27am
Try setting diagram.RoutingOptions.Anchoring to Keep or Reassign before calling RouteAllLinks.
CODISMA
Reply #2 - Oct 6th, 2022 at 8:32am
Hi Slavcho,
Thanks you for your reply.
I already try this Sad
Online
Reply #3 - Oct 6th, 2022 at 8:43am
Try also setting diagram.LinkRouter to a GridRouter instance.
