Normal Topic Scheduling for Java Swing, V2.2.1 (Read 2122 times)
Oct 8th, 2022 at 2:55pm
We have released version 2.2.1 of MindFusion.Scheduling for Java Swing. The new version includes:
Reorder resources
  • Enable the AllowReorderResources property of TimetableSettings to let users reorder resource columns in timetable view when GroupType is set. The ReorderIndicatorColor and ReorderIndicatorWidth properties let you customize the appearance of insertion indicator line.
  • Enable the AllowReorderResources property of ResourceViewSettings to let users reorder rows in resource view when GroupType and SecondaryGroupType are set. The ReorderIndicatorColor and ReorderIndicatorWidth properties let you customize the appearance of insertion indicator line.
  • New ItemHeaderText and ItemDescriptionText members of CustomDrawElements let you custom-draw item's text labels.
  • Enable the ExtendedCurrentTimeMarker property of TimetableSettings or TimelineSettings to make current-time marker span the full extent of timetable / resource view (instead of only header area).
  • The createImage method lets you export a bitmap representing current calendar view.
  • Fixed label rotation angles in horizontal timetable view.
  • Fixed RangeSelector exception when running under the Nimbus Look and Feel.
Distribution for the latest version can be downloaded here, or from the clients area on our site.
https://mindfusion.eu/JPlannerTrial.zip
Updated JAR is also available at the Maven Central Repository:
https://search.maven.org/artifact/eu.mindfusion/scheduling
