Normal Topic Links labels rotation. (Read 1164 times)
skaladra
Oct 12th, 2022 at 6:11am
Hello support! I have a following question. Is rotation of links labels supported? I can't find the solution. By labels i mean the following https://www.mindfusion.eu/onlinehelp/wpfdiagram/T_MindFusion_Diagramming_Wpf_Lin...
Re: Links labels rotation.
Reply #1 - Oct 12th, 2022 at 1:52pm
There's no built-in support at this time. You can only set TextStyle to rotate link's Text value.
ItemLabel ultimately inherits from UIElement, so you could probably apply your own rotation to some extent (e.g. it won't be saved automatically in diagram files) by setting the UIElement.RenderTransform property.
