Normal Topic Links labels bounds. (Read 2454 times)
skaladra
Oct 18th, 2022 at 10:07am
Hello support. I am working with links labels and Link text property as well. It seems like link label bounding box already has some padding added, because the box is larger than link text property even with it's padding set to zero. I've added an attachment where top text item is link text property, and the bottom is link label. Do you have a solution for this?
Re: Links labels bounds.
Reply #1 - Oct 18th, 2022 at 10:23am
Check if that's not coming from the Margin property. ItemLabel sets its default value to 2:
MarginProperty.OverrideMetadata(
	typeof(ItemLabel),
	new FrameworkPropertyMetadata(new Thickness(2)));
skaladra
Reply #2 - Oct 18th, 2022 at 11:04am
Unfortunately, no. It seems like margin just moves the label. The first picture is label with zero margin (0, 0, 0, 0) and the second is label with margin set to 30 (30, 30, 30, 30).
Reply #3 - Oct 18th, 2022 at 1:16pm
Right, it's hard-coded padding when you set Brush for background. This build lets you change it using TextPadding property:
https://mindfusion.eu/_beta/wpfdiag383.zip
label.TextPadding = new Thickness(0);
skaladra
Reply #4 - Oct 18th, 2022 at 1:43pm
It seems like text padding doesn't affect the label background. I have 3.8.3 as well and if I set any padding (let it be 20 or 0), the actual background size isn't changing.
Reply #5 - Oct 18th, 2022 at 3:38pm
TextPadding should affect it with new build our developer created today; have you downloaded again or using older preview assemblies?
skaladra
Reply #6 - Oct 19th, 2022 at 4:11am
I used older versions. Thank you, I'll try the newest solution.
skaladra
Reply #7 - Oct 19th, 2022 at 4:22am
Yeah, now setting text padding works perfectly. Thank you so much.
