Normal Topic Diagramming for JavaScript, V4.2.3 (Read 1289 times)
Nov 1st, 2022 at 8:25am
We have released version 4.2.3 of MindFusion JavaScript Diagram library. It contains the following new features and improvements:
Radial tree layout
The RadialTreeLayout class arranges tree levels in concentric circles around the root. The levelDistance property specifies the distance between adjacent circles. The direction property specifies placement of first child node. Set stretchFactor to a value larger than 1 in order to stretch level circles into ellipses, providing more space for the layout when using wider nodes.
  • strokeDashArray and strokeDashOffset properties let you set custom dash patterns when strokeDashStyle is set to Custom.
  • Styled text now supports <size=N> element letting you set font size.
  • enableStyledText property added to ItemLabel lets you format labels using HTML-like format flags.
  • enableWrap and maxWidth properties of ItemLabel let you wrap label's text.
  • The ArrowHeads class exposes arrowhead shapes as static methods returning respective predefined shape.
  • Fixed linkTextStyle exception.
Updated scripts are also available as @mindfusion/diagramming NPM package.
