Normal Topic SVG incorrectly rendered (Read 1418 times)
rdwheeler
Nov 2nd, 2022 at 5:29pm
I'm having trouble with the rendering of a simple SVG in vs 6.8.4. I'm attaching a screenshot of the shape as rendered in Illustrator, and then as rendered by SvgNode. Here is the actual SVG string:
<?xml version="1.0" encoding="UTF-8"?>
<svg id="Layer_2" data-name="Layer 2" xmlns="http://www.w3.org/2000/svg" width="150" height="150" viewBox="0 0 150 150">
  <g id="SettingsButton">
    <g id="Circle">
      <circle cx="75" cy="75" r="71.5" style="fill: #2a5f55;"/>
      <path d="M75,7c37.5,0,68,30.5,68,68s-30.5,68-68,68S7,112.5,7,75,37.5,7,75,7m0-7C33.58,
0,0,33.58,0,75s33.58,75,75,75,75-33.58,75-75S116.42,0,75,0h0Z" style="fill: #2a3f55;"/>
    </g>
    <path id="GearIcon" d="M81.86,27h-13.71s-2.4,15.09-2.4,15.09c-2.74,.69-5.14,1.71-7.2,3.09l-12.34-8.9
1-9.6,9.6,8.91,12.34c-1.37,2.4-2.4,4.8-3.09,7.2l-15.43,2.74v13.71s15.09,2.4,15.0
9,2.4c.69,2.74,1.71,5.14,3.09,7.2l-8.91,12.69,9.6,9.6,12.34-8.91c2.4,1.37,4.8,2.
4,7.2,3.09l2.74,15.09h13.71s2.4-15.09,2.4-15.09c2.74-.69,5.14-1.71,7.2-3.09l12.3
4,8.91,9.6-9.6-8.91-12.34c1.37-2.4,2.4-4.8,3.09-7.2l15.43-2.74v-13.71s-15.09-2.4
-15.09-2.4c-.69-2.74-1.71-5.14-3.09-7.2l8.91-12.34-9.6-9.6-12.34,8.91c-2.4-1.37-
4.8-2.4-7.2-3.09l-2.74-15.43Zm6.98,48c.22,17.75-27.61,17.75-27.38,0-.22-17.75,27
.61-17.75,27.38,0Z" style="fill: #fcb01a;"/>
  </g>
</svg>
Re: SVG incorrectly rendered
Reply #1 - Nov 3rd, 2022 at 8:13am
Well, it looks worse in browsers, or maybe the forum software has rendered incorrectly the XML you've copied -
https://mindfusion.eu/_samples/gear.svg
Our developer suspects we don't support correctly the S shortcut syntax for cubic Bezier curves, you might try replacing these with full C commands.
Reply #2 - Nov 3rd, 2022 at 9:23am
The S path element is supposed to follow another curve to reflect its control point, and since it's not in the gear SVG, the node was drawing some random points. This build should fix that -
https://mindfusion.eu/_temp/fcnet_svg_s.zip
Also the S curves in the gear have overlapping points, meaning they describe straight line segments, so you could replace them with L for a bit faster parsing and drawing.
rdwheeler
Reply #3 - Nov 9th, 2022 at 5:51pm
The new build work; thank you gentlemen!
FYI, I am no SVG expert so appreciate the advice on optimizing my SVG. So, I looked into getting the same code optimized to the below. However, while that loads fine in Chrome, it throws an "Index out of range error" when loaded via
                             var doc = new XmlDocument();
                             doc.Load(new MemoryStream(svgString.ToBytes()));
                             Content = new SvgContent();
                             Content.Parse(doc);
<svg xmlns="http://www.w3.org/2000/svg" width="150" height="150" viewBox="0 0 150 150"><circle cx="75" cy="75" r="71.5" fill="#2a5f55"/><path fill="#2a3f55" d="M75 7c37.5 0 68 30.5 68 68s-30.5 68-68 68S7 112.5 7 75 37.5 7 75 7m0-7C33.58 0 0 33.58 0 75s33.58 75 75 75 75-33.58 75-75S116.42 0 75 0z"/><path fill="#fcb01a" d="M81.86 27H68.15l-2.4 15.09c-2.74.69-5.14 1.71-7.2 3.09l-12.34-8.91-9.6 9.6 8.91 12.34c-1.37 2.4-2.4 4.8-3.09 7.2L27 68.15v13.71l15.09 2.4c.69 2.74 1.71 5.14 3.09 7.2l-8.91 12.69 9.6 9.6 12.34-8.91c2.4 1.37 4.8 2.4 7.2 3.09l2.74 15.09h13.71l2.4-15.09c2.74-.69 5.14-1.71 7.2-3.09l12.34 8.91 9.6-9.6-8.91-12.34c1.37-2.4 2.4-4.8 3.09-7.2l15.43-2.74V68.16l-15.09-2.4c-.69-2.74-1.71-5.14-3.09-7.2l8.91-12.34-9.6
-9.6-12.34 8.91c-2.4-1.37-4.8-2.4-7.2-3.09l-2.74-15.43zm6.98 48c.22 17.75-27.61 17.75-27.38 0-.22-17.75 27.61-17.75 27.38 0z"/></svg>
Reply #4 - Nov 11th, 2022 at 8:10am
Our parser doesn't like the c-2.74.69 path command. Adding a space before the second dot fixes it.
MindFusion
