Normal Topic Virtual Keyboard for WinForms, V5.0.2 (Read 6113 times)
Nov 11th, 2022 at 10:05am
We have released version 5.0.2 of WinForms Virtual Keyboard control. It contains the following new features and improvements:
.NET 6 support
The Virtual Keyboard distribution now includes assemblies for .NET 6. Locally installed assemblies don't show automatically in toolbox at this time, you can either add them manually or through Nuget package manager.
  • CurrentCase property of RegularKey returns key's label reflecting current state of modifier keys.
  • The control now tracks state of Caps-lock and Shift keys of physical keyboard (if one is attached to the system).
  • Enable PasswordMode to stop highlighting pressed or hovered keys.
  • ChangeLanguage overloaded methods let you set current language either by Windows SDK layout identifier or by CultureInfo.
  • The CurrentLayout property returns the KeyboardLayout instance currently in use.
  • Fixed unequal layout margins; now the keyboard should center correctly inside its layout area.
The latest version can be downloaded here, or from the clients area on our site:
https://mindfusion.eu/KeyboardWinForms.zip
Updated assemblies are also available as MindFusion.Keyboard NuGet package.
