Normal Topic Extra space of link when it is selected. (Read 876 times)
skaladra
Nov 23rd, 2022 at 12:09pm
Hello, MindFusion Team. I have moving cursor when I hover any diagram item(default cursor in other cases). When diagram link is selected, it seems like it has extra space where the origin and destination points are located(see attachment). How can I get rid of this extra space?
Re: Extra space of link when it is selected.
Reply #1 - Nov 24th, 2022 at 7:23am
Try setting a small LinkHitDistance. Note that the default 0 is considered 5mm in any unit.
skaladra
Reply #2 - Nov 28th, 2022 at 7:50am
It seems to be working. But if I increase the line weight it becomes difficult to hit test it. Is there an option to set this property to a concrete line?
Reply #3 - Nov 28th, 2022 at 10:41am
If you are using a custom link class (to draw non-standard selection frame?), you could try also overriding the bool ContainsPoint(point) method and return ContainsPoint(point, threshold) overload with StrokeThickness as argument instead of diagram's LinkHitDistance. This method is called when Diagram.HitTestPriority == ZOrder.
