Normal Topic SVG load issue (Read 816 times)
nullable
SVG load issue
Dec 1st, 2022 at 11:23am
Hello, I'm trying to load an svg image into an SvgNode, but an IndexOutOfRangeException occurs when parsing the svg, please check it, the files is attached below
var node = new SvgNode();
var svgContent = new SvgContent();
svgContent.Parse(@"D:/personal/sample_1920×1280.svg");
Diagram.Items.Add(node);
sample_1920G_1280.svg (Attachment deleted)
Re: SVG load issue
Reply #1 - Dec 6th, 2022 at 8:40am
This build should fix it -
https://mindfusion.eu/_beta/wpfdiag39.zip
