Normal Topic SVG image is not transformed (Read 6309 times)
Ivan K.
Dec 6th, 2022 at 1:09am
Hi all! I have an issue with import of SVGs that contain images.
In continuation to this thread: https://mindfusion.eu/Forum/YaBB.pl?num=1661424075/3#3
If image has transform matrix - transformation is not applied on the resulting diagram. Could you please check?
var svgNode = new SvgNode();
SvgContent content = new SvgContent();
content.Parse(@"D:/personal/img.svg");
svgNode.Content = content;
diagram.Nodes.Add(svgNode);
Please see attachments for details.
Re: SVG image is not transformed
Reply #1 - Dec 6th, 2022 at 8:42am
This build applies image transform -
https://mindfusion.eu/_beta/wpfdiag39.zip
Ivan K.
Reply #2 - Dec 7th, 2022 at 4:27am
It works. Thank you!
nullable
Reply #3 - Dec 9th, 2022 at 10:40am
Transform is working now, but it seems like opacities of the images cannot be parsed back to svgContent. Could you verify this?
Ivan K.
Reply #4 - Dec 9th, 2022 at 11:30am
Hi team. Transform is working fine, but there is a problem with a quality of exported document.
If SvgNode.Content contains raster image, SVG exporter produces low-quality copy of it (see attached documents).
Could you please verify?
var exporter = new SvgExporter();
var ms = new MemoryStream();
exporter.InvisibleItems = false;
exporter.Export(diagram, "result.svg");
Reply #5 - Dec 12th, 2022 at 5:45pm
Try this build for image quality -
