Normal Topic Drawing anchor points underneath a shape node (Read 900 times)
dpru2
Dec 9th, 2022 at 10:15pm
Right now it seems like anchor points are always drawn on top of a shape node. Is there a way to draw them underneath the shape node? So basically reverse the order of drawing, or change the z-order?
Edit:
Alternatively, I'd like to be able to only draw anchors when a node is selected.
Re: Drawing anchor points underneath a shape node
Reply #1 - Dec 12th, 2022 at 8:40am
You could set diagram.DrawAnchors = Never and draw the points from DrawBackground event handler, e.g. by calling the public node.DrawAnchors method.
For the alternative, set diagram.ShowAnchors = ShowAnchors.Selected;
