Normal Topic Prevent node deletion (Read 816 times)
Chc
Jan 4th, 2023 at 6:16pm
Is there a way to prevent deleting a node by pressing the key combination <shift><delete>?
The NodeDeleting event is only called with the key <delete>. I can catch that one. The event OnKeyDown is not called at all.
Thanks in advance
Re: Prevent node deletion
Reply #1 - Jan 4th, 2023 at 7:35pm
Apparently that's another shortcut for ApplicationCommands.Cut, along with Ctrl+X. The diagram handles it internally by calling CutToClipboard method, without validating individual nodes in the selection. Try replacing the command binding as in this post -
https://mindfusion.eu/Forum/YaBB.pl?num=1335340756/2#2
