Normal Topic SVG performance slowdown (Read 931 times)
nullable
Jan 18th, 2023 at 4:34am
Hi, we have a huge performance drop with large svg files (example in attachments). I just want to clarify, is it because vector-based images store geometric points and data and cause rendering slowdown as long as it updates. Сan we possibly do something with this?
Re: SVG performance slowdown
Reply #1 - Jan 18th, 2023 at 7:46am
SvgNode was intended for showing icons in the diagram and doesn't do any caching of render results at this time. A large SVG drawing would cause multiple calls to RenderContext's draw-primitive methods when node's coordinates change, and will generally create large WPF visual tree slowing down screen refreshes.
You could try caching SVG renderings yourself by creating RenderTargetBitmap from SvgNode, and then only drawing the bitmap using a transparent ShapeNode or a custom type:
var bounds = new Rect(0, 0, 400, 200);
var svgRenderer = new SvgNode
	Content = SvgContent.FromFile("source.svg"),
	Bounds = bounds,
	Transparent = true // hide shape geometry
var cache = new RenderTargetBitmap(
	400, 200, 96, 96, PixelFormats.Default);
var visual = new DrawingVisual();
var context = visual.RenderOpen();
svgRenderer.DrawLocal(context, diagram.PrintOptions);
context.Close();
cache.Render(visual);
var node = new ShapeNode
	Image = cache,
	Bounds = bounds,
diagram.Nodes.Add(node);
// todo: refresh cache when node resizes, but maybe only
// when scale changes substantially to not redraw very often
Reply #2 - Jan 18th, 2023 at 7:57am
with that approach you'd need to switch temporarily back to SvgNode for the svg-to-svg exports you were showing in older thread, if you want vector graphics preserved.
nullable
Reply #3 - Jan 18th, 2023 at 9:16am
Thank you!
