Normal Topic Links crossing inconsistencies (Read 1662 times)
nullable
Jan 23rd, 2023 at 7:35am
Hello mindfusion team.
I wanted to know if there are options to disable link breaks for some cases when, for instance, one link crosses another only at right angle. Because when I move link down, intersection is not drawn.
nullable
Re: Links crossing inconsistencies
Reply #1 - Jan 23rd, 2023 at 10:42am
Please also check the following issue: If I draw blue link with LinkCrossings set to True through the black links that have LinkCrossings set to False, the crossings are drawn.
Reply #2 - Jan 23rd, 2023 at 10:53am
You can disable crossing augmentations on individual links by setting their DrawCrossings property to false. In last example the owner of the crossing graphics is the blue link, so you'd need to set false for it.
nullable
Reply #3 - Jan 23rd, 2023 at 11:26am
I understand what you mean. I just wanted to know if there is possibility to totally ignore other links if they have DrawCrossings set to false, without disabling it in blue link.
Reply #4 - Jan 23rd, 2023 at 1:04pm
You can also control that somewhat by changing relative Z order of links combined with DrawCrossings (arcs are drawn for the link at higher Z plane). But it sounds you want to toggle visibility per-crossing, which is not supported at this time.
nullable
Reply #5 - Feb 2nd, 2023 at 8:47am
Thanks for reply. I would like to know if you have visibility per-crossing feature in your nearest future plans. Wink
nullable
Reply #6 - Feb 2nd, 2023 at 8:52am
Also I need your feedback about the first message. Is the behavior there considered correct?
Reply #7 - Feb 3rd, 2023 at 1:21pm
We'll try to add some validation event for next release to let the application hide per-crossing adornments. Please attach saved diagram file if you think it displays some crossings wrongly, and our developer will investigate.
Reply #8 - Mar 15th, 2023 at 8:48am
Check if new ValidateLinkCrossing event here will work for you -
https://mindfusion.eu/_beta/wpfdiag391.zip
diagram.LinkCrossings = LinkCrossings.Cut;
diagram.ValidateLinkCrossing += OnValidateLinkCrossing;
void OnValidateLinkCrossing(object sender, LinkCrossingEventArgs e)
	if (e.BottomLink.StrokeDashStyle != DashStyles.Solid)
		e.Cancel = true;
Event arguments include -
public DiagramLink TopLink { get; set; }
public int TopSegmentIndex { get; set; }
public DiagramLink BottomLink { get; set; }
public int BottomSegmentIndex { get; set; }
public Point IntersectionPoint { get; set; }
public bool Cancel { get; set; }
nullable
Reply #9 - Mar 16th, 2023 at 6:21am
Hello! Thank you for such validation, it works just as expected.
