Normal Topic Diagramming for Windows Forms, V6.8.5 (Read 1387 times)
Jan 24th, 2023 at 10:54am
We have released version 6.8.5 of FlowChart.NET. It contains the following new features and improvements:
Styled supplementary labels
The EnableStyledText property of ItemLabel lets you enable or disable styled text rendering in node and link labels. Styled text can contain italic, bold, underline, subscript, superscript and color attributes applied to its substrings. The attributes are specified using HTML-like formatting tags embedded in the raw text, listed in Text Attributes and Formatting section of the help file.
SvgNode improvements
  • SvgNode can load SVG styles by id and type CSS selectors.
  • Bitmap images embedded in SVG can now be decoded from non-PNG formats.
  • Improved rendering of text embedded in SVG.
  • Fix for S command in path data (shortcut syntax for cubic Bezier curves) when not following another curve.
  • Support for transforms on embedded bitmaps.
  • Support for new-line symbols in style and path data attributes.
Fixed bugs
  • Fix for link positions not reindexing correctly when spatial index is enabled.
Updated assemblies are also available as MindFusion.Diagramming NuGet package.
