Normal Topic undo can‘t complete once (Read 738 times)
CW
Mar 15th, 2023 at 11:16am
i use dragdrop to put my node to diagram view. when i use undo
like:
        private void undo_Click(object sender, EventArgs e)
#if !STANDARD
            diagram.UndoManager.Undo();
#endif // !STANDARD
then i need to click three times. why it can't complete once?
Re: undo can‘t complete once
Reply #1 - Mar 15th, 2023 at 4:26pm
If creating the node from a custom drag-and-drop handler, try using composite commands -
https://www.mindfusion.eu/onlinehelp/flowchartnet/Composite_Commands.htm
If modifying the node from NodeCreated event raised after dragging from NodeListView, try calling MergeUndoRecords -
https://www.mindfusion.eu/onlinehelp/flowchartnet/M_MindFusion_Diagramming_Comma...
