Normal Topic KeyDown/KeyUp are not done correctly (Read 2041 times)
GB_Rollo
Mar 17th, 2023 at 10:23am
Using this site to analyse the behaviour of your virtual keyboard, the keydown/keyup events are not used correctly. Specially when we keep pressing down a key.
It send always keydown + keyup events repeatly. But when doing same action on OSK or physical keyboard, we can see a lot of keydown event until one final keyup.
https://w3c.github.io/uievents/tools/key-event-viewer.html
Can you please change your virtual keyboard to act the same as OSK and physical keyboard ? I mean one/multiple event/s keydown and one event keyup when long pressing a key.
Thank you,
Guillaume
Re: KeyDown/KeyUp are not done correctly
Reply #1 - Mar 20th, 2023 at 9:28am
We'll have it in mind for next releases. Logically either repeat implementation should lead to same result when entering texts. We imagine this would matter only for some inertia / physics calculations, like slider speed animation when moving it with arrow keys? Or do you need this for playing computer games from virtual keyboard? Wink
GB_Rollo
Reply #2 - Mar 20th, 2023 at 1:37pm
Yeah in my case it's not when entering texts or playing  Wink but moving a cursor into something that look like a graph.
The application having this "issue" is an old third party application and in that case it surelly want keyboard acting like the physical keyboard or the OSK.
Thank you,
Guillaume
Reply #3 - May 1st, 2023 at 10:04am
Try setting vkb.RepeatDownOnly = true with this build -
https://mindfusion.eu/_temp/vkb_repeat.zip
GB_Rollo
Reply #4 - May 5th, 2023 at 8:05am
I'll try your solution a soon as possible and give you feedback.
Thank you,
Guillaume
GB_Rollo
Reply #5 - May 30th, 2023 at 11:07am
Hi Slavcho,
I confirm, this fix solve the issue.
Can you please add this to the next release and can we expect this release soon ?
Thank you,
Guillaume
Reply #6 - Jun 1st, 2023 at 7:02am
At this time this has been released as part of our WPF controls pack -
https://www.nuget.org/packages/MindFusion.Pack.Wpf/
Your license key should work for the keyboard assembly from it. We hope to release the standalone control in few weeks.
