Normal Topic ResizeToFitText maybe not working in all cases (Read 1793 times)
David Long
Mar 21st, 2023 at 3:43pm
Does the function "ResizeToFitText(FitSize.KeepWidth);" work in all cases? The box in question has text padding set up as follows:
            box.TextPadding = new Thickness(1, 1, 1, 1);
The font used is:
            Font ChartFont = new Font("Segoe UI Semibold", 10F, FontStyle.Regular);
The text format is as follows:
            box.TextFormat                      = new StringFormat();
            box.TextFormat.Alignment       = StringAlignment.Center;
            box.TextFormat.LineAlignment = StringAlignment.Center;
But the box is not resized correctly (see 3rd box along in the screen-shot which has two letters missed off the end (it should be ...task are poor)
Looking at the debugger, the box height is set to 25.9mm which is not quite enough.
DavidL
Re: ResizeToFitText maybe not working in all cases
Reply #1 - Mar 22nd, 2023 at 3:30pm
Try this build -
https://mindfusion.eu/_temp/winforms_fit_width.zip
David Long
Reply #2 - Mar 22nd, 2023 at 4:33pm
Thanks, that fixes the problem. Is it possible to have signed .NET 4 assemblies for FlowChart.NET Pro version 6.8.4? This is the last version available on our licence.
Many thanks
DavidL
Reply #3 - Mar 23rd, 2023 at 6:33am
We won't be backporting this to old versions. If you don't want to move to current one, you can work around like this:
if (fit == FitSize.KeepWidth && !box.EnableStyledText)
    var r = box.Bounds;
    box.Resize(r.Width - box.TextPadding.Width, r.Height);
    box.ResizeToFitText(fit);
    box.Resize(r.Width, box.Bounds.Height);
David Long
Reply #4 - Mar 23rd, 2023 at 3:44pm
Ok, thanks, That has fixed the problem.
DavidL
