Normal Topic Spreadsheet for Java Swing, V1.1 (Read 6301 times)
Apr 4th, 2023 at 10:45am
We have released version 1.1 of MindFusion Spreadsheet for Java Swing. It contains the following new features and improvements:
Formula hints
  • Target cells or cell ranges in a formula expression are now color-coded to show the matching area in grid view.
  • The control shows a hint box with function information when user enters a function name in formula.
Formula bar improvements
  • Users can enter a new line in formula bar by pressing Ctrl + Enter.
  • The Tab key now tabs out of formula bar instead of tabulating the text.
  • Changes entered through formula bar are now undoable.
  • Formula bar no longer displays trailing zeros when selecting numeric cells.
  • Formula bar is cleared when changing the active sheet.
  • Date format strings can now contain apostrophes to escape literal values.
  • The cell editor grows when user types longer expressions.
  • valueAs shortcut method for getting cell values of specific types.
  • The sum method of CellRange now includes formula results.
https://mindfusion.eu/JSpreadsheet.zip
Updated JAR is also available at the Maven Central Repository:
https://search.maven.org/artifact/eu.mindfusion/spreadsheet
