Normal Topic Problems with SVG content parsing. (Read 1565 times)
nullable
Apr 17th, 2023 at 8:44am
Hi Mindfusion!
I got an index out of range exception when trying to parse SvgContent of following SVG file. Could you check if there is a problem?
Code:
var xmlDocument = new XmlDocument();
xmlDocument.Load(fileStream);
var svgContent = new SvgContent();
svgContent.Parse(xmlDocument, false);
node.Content = svgContent;
Re: Problems with SVG content parsing.
Reply #1 - Apr 18th, 2023 at 6:35am
Our parser doesn't like the l.27.28 path command. Adding a space before the second dot fixes it.
MindFusion
Reply #2 - Apr 20th, 2023 at 9:50am
New build here should parse that syntax -
https://mindfusion.eu/_beta/wpfdiag392.zip
Reply #3 - Apr 24th, 2023 at 2:56pm
We've fixed this for a few more path commands here -
