When we export diagram (by SvgExporter) with items (SvgNode[]) with overriden
Draw method which call DrawingContext.DrawText with our custom formatted text - the exporter will create XML with <text> block. The main goal of the issue - main attributes will not be saved (FontSize, FontFamily etc). When we trying to read the SVG by another library - it can't be restored correctly, because the main attributes isn't provided.
Demo is attached, code examples too.
Also we can't draw text as path, because we will face another bug
https://mindfusion.eu/Forum/YaBB.pl?num=1665982089. Some letters will be filled.
/// <summary>
/// Diagram node that draw the text.
/// </summary>
internal class TextDiagramItem : DiagramNode
private readonly string text;
private readonly Point textDrawPoint;
private readonly FlowDirection flowDirection = FlowDirection.LeftToRight;
private readonly Typeface typeface = new Typeface(new FontFamily("Heebo"), new FontStyle(), new FontWeight(), new FontStretch());
private readonly double fontSize = 36;
private readonly Brush foreground = Brushes.Blue;
/// <summary>
/// Constructor.
/// </summary>
/// <param name="text">Text to draw.</param>
/// <param name="textDrawPoint">Text draw point.</param>
public TextDiagramItem(string text, Point textDrawPoint)
this.text = text;
this.textDrawPoint = textDrawPoint;
// See resulting svg <text> and its attributes.
// Not expected result.
FontSize = fontSize;
FontFamily = new FontFamily("Heebo");
/// <inheritdoc/>
public override void Draw(DrawingContext graphics, MindFusion.Diagramming.Wpf.RenderOptions options)
var formattedText = new FormattedText(text, CultureInfo.CurrentCulture, flowDirection, typeface, fontSize, foreground);
graphics.DrawText(formattedText, textDrawPoint);
private void MainWindow_Loaded(object sender, RoutedEventArgs e)
var diagram = new Diagram()
Bounds = new Rect(0, 0, 1920, 1080),
var point = new System.Windows.Point(100, 200);
var text = new TextDiagramItem(text: "Some text", point);
diagram.Items.Add(text);
// See output [diagram.svg] file and its <text> attributes.
// The <text> attribute must contains font-size = 36, font-family=heebo...
// And other attrs which configured in text diagram item.
var ms = ExportDiagram(diagram);
ms.Seek(0, SeekOrigin.Begin);
var svg = SvgDocument.Open<SvgDocument>(ms);
// See svg [children] collection and SvgText instance.
// It parses the svg file and can't parse FontSize, FontFamily etc. correctly.
var sizedImage = new Bitmap((int)svg.Width.Value, (int)svg.Height.Value);
svg.Draw(sizedImage);
sizedImage.Save("test.png", ImageFormat.Png);
private static Stream ExportDiagram(Diagram diagram)
var exporter = new SvgExporter()
SetClipPaths = true,
var ms = new MemoryStream();
exporter.Export(diagram, "diagram.svg");
exporter.Export(diagram, ms);
return ms;
See <text> block (and its attributes) in attached
diagram.svg file.
MindfusionDemo.zip contains solution which you can debug and review the text nodes which will be parsed by Svg.NET library. The text node doesn't contains a correct font size, font family etc.
