Hot Topic (More than 10 Replies) Links intersection display when handle is close to crossing (Read 2814 times)
nullable
Re: Links intersection display when handle is close to crossing
Reply #15 - May 11th, 2023 at 6:36am
Attempt №2
Reply #16 - May 15th, 2023 at 9:21am
Quote:
but the classes have too many domain properties and it is impossible to make all of them serializable
Domain properties shouldn't be related to position of crossing decorations. Please only register the classes (without overriding serialization methods) and attach the xml file, so we can trace this with your node and link coordinates.
nullable
Reply #17 - May 16th, 2023 at 6:00am
I do register only classes, but face a problem when I need to mark many classes as serializable, because they are being used as property in that classes. Maybe you could recommend any ignore attribute for these properties?
Reply #18 - May 16th, 2023 at 6:48am
We do not need to see values of you custom properties for derived node types, but only node and link coordinates from SaveToXml result. It should be enough to register the custom DiagramItem type, without overriding its serialization methods to handle the added properties. Custom types might matter if you assign their instances to Tag or Id properties. In such case try handling SerializeTag event and just set args.Handled = true.
Alternatively, export coordinates in some simple format as below. Restoring the diagram from that should still show your link crossing positions for our developer to inspect:
var writer = new StreamWriter("diagram.txt");
writer.WriteLine(diagram.Nodes.Count);
foreach (var node in diagram.Nodes)
	writer.WriteLine(node.Bounds);
writer.WriteLine(diagram.Links.Count);
foreach (var link in diagram.Links)
	var orgIndex = diagram.Nodes.IndexOf(link.Origin);
	var dstIndex = diagram.Nodes.IndexOf(link.Destination);
	writer.Write("{0} {1} {2} {3} ",
		orgIndex, dstIndex, (int)link.Shape, link.ControlPoints.Count);
	foreach (var point in link.ControlPoints)
		writer.Write(point);
		writer.Write(" ");
	writer.WriteLine();
writer.Close();
nullable
Reply #19 - May 17th, 2023 at 5:35am
I do understand that you don't need to see my domain properties. But the trick is that I simply can't export the diagram having it. I get the following exception
System.Runtime.Serialization.SerializationException: 'Type 'DomainClass' in Assembly 'Domain, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null' is not marked as serializable.'
But anyway, if you are okay with the text coordinates, I've imported it successfully.
Reply #20 - May 18th, 2023 at 2:08pm
It should try using Serializable only if those classes are used as (part of) Tag or Id values, and you can skip them by handling SerializeTag event.
The problem with missed decoration was that points are not collinear, with small difference in Y coordinates. This build give them a couple of pixels leeway -
https://mindfusion.eu/_beta/wpfdiag393.zip
nullable
Reply #21 - May 19th, 2023 at 5:10am
It is working as expected. Thank You! Smiley
