Normal Topic OnClick Event not detected. (Read 2513 times)
senthilnathan
May 23rd, 2023 at 7:44am
Hi sir,
We create a flow by using asp.net diagram. However if the flow is too long, when click on the diagram item, it does not detected the item properties if user scroll down the browser. In this example each item assigned with ID as well as tag property.
This problem occurs in chrome and edge. There's no issue with firefox
Re: OnClick Event not detected.
Reply #1 - May 23rd, 2023 at 8:15am
What ClientSideMode are you using, and does the browser show any errors in console?
Reply #2 - May 30th, 2023 at 9:58am
What version of the library are you using? Our developer remembers issues like this when at one point browsers started reporting scroll position as floating point numbers instead of integers, breaking server side parsing code. That should be fixed in releases since then.
