Normal Topic How to detect a cell content change? (Read 479 times)
Ale
May 26th, 2023 at 8:13am
I'm new in the forum since I'm evaluating the Spreadsheet.
THe documentation is poor and I have some problems to find the answers.
Now I need to detect in the spreadsheet component every cell content change. I tried to use the event "InplaceEditEnded" but does not fire when, for example, I do copy/paste (pasted content in the cell does not fire that event).
I need to detect every cell change, also when the spreadsheet load a sheet, in fact if the cell contains some specific text I need to perform some activities. This is true also when I load the sheet since I need to know which cells contain the text.
How can I achieve this?
Thank you for your help!
Re: How to detect a cell content change?
Reply #1 - May 26th, 2023 at 9:41am
CellChanged event should be raised for edited values, copy/paste and auto-fill.
You won't get change events while a file loads. You could loop over non-empty cells after loading to get their content:
foreach (var cell in worksheet.Cells)
	Debug.WriteLine(cell);
Ale
Reply #2 - May 26th, 2023 at 1:44pm
OK, understood. Thank you  Smiley
