Normal Topic How to read cell value in a custom function? (Read 694 times)
Ale
May 26th, 2023 at 4:06pm
I'm creating some custom functions using the code (C#):
public class CustomFunctions : IExpressionEvaluator {
        int a = 0;
        public object EvaluateIdentifier(IExpressionEvaluatorContext context, string identifier) {
            return null;
public object InvokeFunction(IExpressionEvaluatorContext context, string name, IList parameters) {
            if(name == "FUNC_A") {
                // HERE: how to read the current cell value?
                return "Value:" + (new Random()).Next().ToString();
// BLA BLA BLA .... CODE
As you can see in the code, this piece of program is executed everytime something is changed in the sheet (automatic recalculation).
I need, "// HERE:" (see the code) to read the value that I previously returned in the previuos calculation (see the code: "return "Value:" + (new Random()).Next().ToString();"). This values is shown in the cell (normally in the sheet we can see the cell value not the formula).
In the formula recalculation I need to read this value.
How can I achieve this in this custom defined formula?
Thank you
Re: How to read cell value in a custom function?
Reply #1 - May 29th, 2023 at 7:22am
This build adds context.OldValue property -
https://mindfusion.eu/_beta/spreadwin_eval.zip
It will just return the formula string if never evaluated before.
Ale
Reply #2 - May 29th, 2023 at 9:01am
Simply amazing! Thank you!
Ale
Reply #3 - May 29th, 2023 at 2:11pm
UPDATE: I think the behaviour of "OldValue" is not correct Cry since, for example, when I insert a formula in a cell for the first time, OldValue should be NULL since the cell was initially empty, instead it contains the formula inserted! Shocked
See the attached screenshot (I used the custom formula "CAREA(2)" just for testing).
It means that the first time I insert a formula OldValue contains the formula self, instead when a recalculation is performed (because I changed something in another place of the sheet), OldValue contains the previously calculated value.
I think, in order to let OldValue have a coherent behaviour, when a new formula is inserted then OldValue should be "" or NULL (maybe NULL is more logical).
Instead if the cell already contains a formula, OldValue should ALWAYS contain the old formula result (this is not happening, in fact if I modify the formula in Old Value I get the formula I just inserted).
Thank you
Reply #4 - May 30th, 2023 at 7:58am
New build here returns null if current formula never evaluated -
Ale
Reply #5 - May 30th, 2023 at 8:21am
Thank you  Cheesy
I hope this modification could be useful to other people also
