Normal Topic Draw Image (Read 2310 times)
donep
Love MindFusion
Draw Image
Jun 5th, 2023 at 8:21am
I just tried Mindfusion MAUI diagram and need help displaying an image on  "override Draw(IGraphics graphics, RenderOptions options)" ShapeNode.
Could you help me how to draw image on "\Resource\image.png" with graphics.DrawImage method.
Thanks for help.
Online
Re: Draw Image
Reply #1 - Jun 5th, 2023 at 2:36pm
You should be able to load the image file by calling ImageSource.FromFile("image.png"); You can set ShapeNode's Image, ImageAlign and ImagePadding properties to display the image in specific area of the node. If you need to draw a second image,call IGraphics.DrawImage method from the override.
donep
Love MindFusion
Re: Draw Image
Reply #2 - Jun 15th, 2023 at 8:20am
I attached an example file to display the image, but it still doesn't work.
Online
Re: Draw Image
Reply #3 - Jun 19th, 2023 at 7:35am
It seems to draw the plus image in my test. On what OS and .NET versions isn't it working for you?
The ImageAlign property will only align if you use standard Image property. Try using this overload to apply alignment for custom-drawn image:
void DrawImage(ImageSource image, Rectangle rect,
	ImageAlignment imageAlign, double rotationAngle, Point pivot);
