Normal Topic Set the Correct Location for a Context Menu (Read 1040 times)
alukes
Jun 25th, 2023 at 2:38am
I want a context menu to appear where I will create a node. I can get the node to be created where it should.
The context menu is always too close to the upper left corner. I am guessing I need to convert rectangle values to pixel values. How do I do that?
Is there a native way to generate a context menu within Mindfusion?
function onClicked(sender, args) {
  var x = args.mousePosition.x;
  var y = args.mousePosition.y;
  contextMenu.style.left = x + 'px';
  contextMenu.style.top = y + 'px';
  contextMenu.style.zIndex = 50;
Re: Set the Correct Location for a Context Menu
Reply #1 - Jun 26th, 2023 at 9:53am
Try the code from this post -
https://mindfusion.eu/Forum/YaBB.pl?num=1683773362/2#2
alukes
Reply #2 - Jun 28th, 2023 at 11:48am
That took care of the problem.
Thanks!
