Normal Topic AutoFill not working when keyboard is inside a template (QWERTY, QWERTZ and AZERTY) (Read 1138 times)
forl
Jun 29th, 2023 at 9:20am
I have been experimenting with the VirtualKeyboard.
When used like this :
<Window ...>
    <Grid>
    <vk:VirtualKeyboard TemplateLayout="{Binding KeyboardLayout}"
                                IsStandAlone="False"
                                AutoFill="True" />
     </Grid>
</Window>
All is fine. When I change from English to German to French I see it automatically change between QWERTY, QWERTZ and AZERTY
However, when I try to instantiate the VirtualKeyboard within a data template, AutoFill doesn't work anymore, and as I change between the languages, the keyboard doesn't update between QWERTY, QWERTZ and AZERTY?
Its very strange? not sure why having it in a template would cause this behaviour?
<Window ...>
    <Window.Resources>
        <DataTemplate DataType="{x:Type local:KeyboardViewModel}">
                                AutoFill="True" />
        </DataTemplate>
    </Window.Resources>
    <Grid>
        <ContentPresenter Content="{Binding KeyboardViewModel}" />
    </Grid>
</Window>
I am using the MindFusion.Keyboard.Wpf 5.0.3 nuget package in a .net 6 WPF project.
<Project Sdk="Microsoft.NET.Sdk">
  <PropertyGroup>
    <OutputType>WinExe</OutputType>
    <TargetFramework>net6.0-windows</TargetFramework>
    <Nullable>enable</Nullable>
    <UseWPF>true</UseWPF>
  </PropertyGroup>
  <ItemGroup>
    <None Remove="Default.xml" />
  </ItemGroup>
  <ItemGroup>
    <EmbeddedResource Include="Default.xml" />
  </ItemGroup>
  <ItemGroup>
    <PackageReference Include="MindFusion.Keyboard.Wpf" Version="5.0.3" />
  </ItemGroup>
</Project>
I have attached the VS project if it helps.
Re: AutoFill not working when keyboard is inside a template (QWERTY, QWERTZ and AZERTY)
Reply #1 - Jun 29th, 2023 at 3:53pm
The control installs some system hooks to track current language and active window. Apparently instantiating from a data template interferes with that somehow (maybe too early to get required win32 handles), so it no longer detects changed language. Our developer will investigate.
forl
Reply #2 - Jul 11th, 2023 at 8:23am
Any update on this?
Reply #3 - Jul 12th, 2023 at 1:07pm
Try this build -
https://mindfusion.eu/_temp/vkb_datatemplate.zip
forl
Reply #4 - Jul 12th, 2023 at 3:54pm
Thank you, that appears to work now.
forl
Reply #5 - Aug 21st, 2023 at 4:32pm
Will you be updating the nuget package for this please?
Reply #6 - Aug 23rd, 2023 at 8:36am
