Normal Topic FlowCharter how to supports multiple documents? (Read 961 times)
Gu Wenwei
Aug 7th, 2023 at 2:25pm
I wanted to create an application that supports multiple documents, but it was unsuccessful.
Adding "private Diagram diagram1" or "private DiagramView diagramView" to File_2 was unsuccessful.
What should I do?
What is the use of "private Diagram _hidden"?
Re: FlowCharter how to supports multiple documents?
Reply #1 - Aug 7th, 2023 at 3:30pm
I imagine you could keep multiple diagrams in a List<Diagram> collection, add a TabControl above the DiagramView, and switch active DiagramView.Diagram to respective collection element when TabControl's active tab changes.
If these diagrams are related to each other and should be saved together, take a look into DiagramDocument and TabbedDiagramView classes, shown in TabbedView example.
The hidden diagram is used just for custom-drawing the items in the ListBox on the right. You could probably replace that listbox with a NodeListView instance.
Gu Wenwei
Reply #2 - Aug 8th, 2023 at 12:57pm
thx, verymuch
