Normal Topic Troubleshooting Drag and Dropping Items (Read 1086 times)
Michael Hopkins
Aug 15th, 2023 at 10:02pm
I have been tasked to add drag and drop functionality to our scheduler that uses JPlanner. I had before removed drag and drop by adding the following code.
calendar.allowDrag = false
calendar.allowMoveUnselectedItems = false
calendar.allowAutoScroll = false
calendar.allowInplaceCreate = false
calendar.allowInplaceEdit = false
So I added instead
calendar.allowDrag = true
calendar.allowMoveUnselectedItems = true
calendar.allowAutoScroll = true
calendar.dragFeedBackType = DragFeedBackType.InsertionLine
calendar.allowInplaceCreate = true
calendar.allowInplaceEdit = true
and I cannot drag the items at all. They don't move. Is there something I am missing. Can anyone think of anything else that would prevent drag and drop functionality on the calendar?
Thanks in advance.
Re: Troubleshooting Drag and Dropping Items
Reply #1 - Aug 16th, 2023 at 10:21am
If you mean dragging internally within the calendar, check if appointments' Locked property isn't enabled by chance, or maybe some validation event handler preventing modifications. If you mean dragging from external controls to the calendar, check the two DragAndDrop sample projects.
Michael Hopkins
Reply #2 - Sep 7th, 2023 at 9:29pm
Yes, I did mean dragging inside the calendar. And yes, it was the locked on the item that was preventing it. Thank you.
